This command disables NTP from the specified VR.
| vr | Specifies disabling NTP on a VR. |
| vr_name | Specifies the VR name to disable NTP from. If a VR name is not specified, the VR of current command context is used. |
The following example disables NTP from a VR named "vr1".
disable ntp vr vr1
This command was first available in ExtremeXOS 22.2.
